I have been having this SSl error for a while and now it became too serious and frustrating to ignore. Manually applying Wildcard SSL seems to be really problematic. I tried to upload SSL through GUI and manually through console. But sometimes it will work and sometimes it does not specially after a reboot. Recently I renewed SSL and tried to upload it in place of the old one and things just wont work. I can only successfully access https://domain.com/webtop without error, but my Android stopped receiving/sending emails, so did my thunderbird. Running systemctl status for httpd httpd-admin postfix seems all good.
What am I doing wrong? The upload process through GUI should all i need no?
Some help to figure this all out would be much appreciated as it is causing major disruption to our email communication. I also recently installed another instance of Nethserver for a client email server but facing the exact same issue.
you need a pem cert and install it for dovecot AFAIK…
But I had the case, where I wanted a renewed wildcard ssl cert and got a wrong one from provider because they don’t have wildcard anymore…so maybe not a webtop problem
I have few ClearOS setups where i installed the same SSL and working perfectly fine. The same SSL also applied to some web servers and hypervisors. This is Comodo Wildcard SSL. The certs are also in PEM format. Sometimes I need to manually rename the certs and the .conf files to make it work, then when server reboots, nethserver rewrites the conf. Thats how it worked for last several months. But this time around manually changing file name in conf or the certs itself not working. I can access the webtop on https:// using a browser just fine. I can see the server receiving emails just fine on Web GUI if Webpo, but my thunderbird or android stopped receiving emails completely.
I think i got SSL part taken care now. Based on suggestions that Nethserver uses templates for SSL, i removed all manual changes including renaming file, deleted custom SSL then uploaded SSL from scratch. My mobile device still wasnt syncing even though it was connected fine. Then i found another article on this forum about sync issue and was suggested to remove the account from mobile device completely, then remove it from Webtop GUI, then reconnect the device again. All seems to work now.
It does look like a good idea to use template for SSL on multi services so users dont need to change different SSL configurations. But i dont think i came across this piece of info on documentation, if i did i missed it totally.
