Fleet Commander
Was reading about this project I didn’t knew about, even when it has some years on its back. It works as a Cockpit plugin.
Fleet Commander is an application that allows you to manage the desktop configuration of a large network of users and workstations/laptops. It is primarily targeted to Linux systems based on the GNOME desktop.
Christian Schaller says in the Fedora Workstation 26 and beyond blog post:
This is a tool targeted at for instance Universities or companies with tens, hundreds or thousands of workstation installation. It gives you a graphical browser based UI (accessible through Cockpit) to create configuration profiles and deploy across your organization.
It has integartion with FreeIPA, and in the future will also support Active Directory.
It seems a great project/product for educational environments and enterprises too! New official web site:
http://fleet-commander.org
/cc @paspo @syntaxerrormmm
