Fail2ban shorewall with nethserver rc4
config set firewalld service status disabled
signal-event runlevel-adjust
do the trick :slight_smile:
I think the right command should be:
systemctl stop firewalld
systemctl disable firewalld
Also systemctl mask ... seems interesting. From systemctl manpage
mask NAME…
Mask one or more unit files, as specified on the command line. This will link these units to /dev/null, making it impossible to start them. This is a stronger version of disable, since it
prohibits all kinds of activation of the unit, including enablement and manual activation. Use this option with care. This honors the --runtime option to only mask temporarily until the next
reboot of the system. The --now option can be used to ensure that the units are also stopped.
However, since rc4 the firewalld.service unit is set disabled by Anaconda (same as NetworkManager). Pre-rc4 installations could see firewalld starting at boot, but shorewall immediately stops it (because of the Conflict= property).
Shall we add it to release notes? /cc @giacomo
Yes, it works!
new version of nethserver-fail2ban nethserver-fail2ban-0.1.3-2.ns7.sdl.noarch.rpm
firewalld is stopped and disabled
