Vacation messages expiration
Make sure to Set AuthName and AuthPassword with the credentials of a sieve admin
0 0 * * * sogo /usr/sbin/sogo-tool expire-autoreply vmail: …
# Email alarms - runs every minutes
# If you need to use SMTP AUTH for outgoing mails, specify credentials to use
# with '-p /path/to/credentialsFile' (same format as the sieve credentials)
#* * * * * sogo /usr/sbin/sogo-ealarms-notify
do we need to use an authentication to smtp for the localhost, not sure ???
please @all can you test the version nethserver-sogo-1.6.8 and report
* Wed Apr 28 2017 Stephane de Labrusse <stephdl@de-labrusse.fr> - 1.6.8-1
- Increase maximum IMAP command line length
- Sogo session are dropped after 24h
- Adjusted sogo cron.d, sieve credentials are in /etc/sogo/sieve.creds
