Ejabberd enable s2s Port 5269
NethServer Version: 7 Final
Module: ejabberd
Hi there,
since I can not connect to other jabber servers, I need to enable s2s and the Port 5269 in ejabberd. How would I do that, since I should not edit config files?
Cheers,
Tony
You need to enable it manually.
Create a template-custom
mkdir /etc/e-smith/templates-custom/etc/ejabberd/ejabberd.cfg/
Put this content inside /etc/e-smith/templates-custom/etc/ejabberd/ejabberd.cfg/80Ports20s2S
,{5269, ejabberd_s2s_in, [{shaper, s2s_shaper}, {max_stanza_size, 131072}]}
Open the port inside the firewall:
config setprop ejabberd TCPPorts 5222,5223,5280,5269
Apply the configuration:
signal-event ejabberd-update
signal-event firewall-adjust
If something doesn’t work as expected, check the syntax of generated ejabberd configuration file.
Thanks so much. As you can probably can imagine, its kind of hard to get into this templating stuff.
Cheers,
Tony
guess you mean this
mkdir -p /etc/e-smith/templates-custom/etc/ejabberd/ejabberd.cfg/
vi /etc/e-smith/templates-custom/etc/ejabberd/ejabberd.cfg/80Ports20s2S
and
signal-event nethserver-ejabberd-update
but whats wrong here?
Problem loading ejabberd config file /etc/ejabberd/ejabberd.cfg : 99: unterminated atom starting with ';\n\t %% Remove t'
I fixed the commands, but probably you should adapt the content of the template-custom.
Please, paste the whole file in a pstebin, since I don’t have a machine to test it right now.
There we go
https://0bin.link/paste/ayIKFKm4#xIqjI8t2MMFmJpNnIjQS4GEhG7gZ4HH-58omqoJKrhY
Sorry for the late response, put these lines inside /etc/e-smith/templates-custom/etc/ejabberd/ejabberd.cfg/80Ports20s2S
    $OUT .= "\n";
    $OUT .= '     ,{5269, ejabberd_s2s_in,  [{shaper, s2s_shaper}, {max_stanza_size, 131072}]}';
    $OUT .= "\n";
Then execute:
I tested it on a dev machine.
Thanks @giacomo that works.
The only problem left is that it still seems not to be possible to connect via TLS. Can I activate that in the same file?
