Delete Letsencrypt Certificate and protocols
I tried to delete an first try of letsencrypt certificate what i choose for the mail server on NS8, so for what i can say the delete action did not work. i get an status, finish delete this certificate, but it is still there. Second Problem i face is is i go to check the protocol from the system i got always told that there are no protocols. if i go on the server via ssh i can read per example the mail.log
After installing from the test repo for getting the last mail app i dont have protocols any longer ant i got this message
There was a similar issue:
this worked, thank you @mrmarkuz
