NethServer Version: NethServer release 7.3.1611 (Final)
Module: Active Directory
I created an Active Directory using Nethserver.
I can join the domain with my Windows 8.1 computer and i see the netlogon and sysvol shares if i go to \mydomain.local
Now when i wanted to connect a FreeNAS to the domain it said i must use TLS.
For i need to use certificates.
Where could i find these certificates ?
My windows computer doesn’t need these to join the domain.
I know it is probably more of a FreeNAS question, but i could join to my Zentyal Active Directory without any problems. Probably was not using TLS
If anyone could help me connect my FreeNAS setup i would greatly appreciate it.
I am trying to connect FreeNAS 11 and im using NethServer release 7.3.1611 (Final) latest.
I’m struggling with this as well. I’m using letsencrypt on my nethserver and I believe the letsencrypt root certificate needs to be imported into freenas. Whoever invented SSL should be shot in the face with a cannon.
Are you still interested to join AD-Members (FreeNAS / Synology) ?
What I can say is that Synology looks much better than FreeNAS. Radius is working to auth my WIFI-Clients… synchronize the Users/Groups under the GUI works good.
FreeNAS has joined AD but I cannot synchronize the Users/Groups under the GUI… I was able to map a FreeNAS-Share with AD-Credentials on my Windows 7 but I do not fully trust this Situation…
Yeah i am still interested of course , you could share it as a howto as someone said above, that would help out many others or the developers.
However i am now more inclined on using FreeNAS as just a NAS, using it mostly for a backup solution and doing the main job with Nethserver .
