stephdl
(Stéphane de Labrusse)
1
I saw that the rpm mirror gets a lot of old rpm. this is for example nethforge : http://packages.nethserver.org/nethserver/7.3.1611/nethforge/x86_64/Packages/
it is possible to clean it easily by a cron, first : yum install yum-utils
then
#! /bin/bash
rm -f $(repomanage --o --keep=2 /path/2/NethServer/7/)
rm -f $(repomanage --o --keep=2 /path/2/NethServer/6/)
you can test it by replacing the command rm by ls or mv/cp to test it first
Ok it is just cosmetic, good weekend
Hi Stephane,
thanks for it.
I think it’s a howto, should we move it to HowTo section?
/cc @alefattorini
giacomo
(Giacomo Sanchietti)
3
The mirrors should be a 1-to-1 copy of the master mirror.
Please note that a repository can contain multiple release of the same RPM for historical reasons and for supporting RPM downgrade.
Thanks for the heads-up. Done
stephdl
5
Centos keeps 5 versions of rpm…ns aims to be full centos compatible
