Hi Michael, my email is aguerrave @ gmail . com .
Regards,
Alejandro Guerra
Regards,
Alejandro Guerra
In the meantime i am trying to combine NS and nxfilter.
Hi Alejandro, can you report about the solution if you are ready?
Hi @Alejandro_Guerra I was reviewing nxfilter and that another system. That is to say;
The detail with locks the easy way is to use transparent proxy. for the following reason, the end customer does not want to learn another key more on his job. We call this resistance to change security policies that would be necessary.
Instead a transparent proxy with association of users on a Windows server AD would be perfect. or failing to install Windows Server LDAP.
In my clients I have configured a proxy with authentication and works perfectly.
we talked over here is to display all users in a domain NethServer after joining a server
Regards
