Hello,
I have just started playing with nethserver 7, and I have a question what is the best way to set up the right writer on each vhost file, with nethserver 6 we did it with .htwritable and I got used to it . But now I do not see how to do it properly, I looked at the docs but did not see/find information.
Have you any clue ?
For a small association I need to install Garradin and garradin ask me to write on several directory in is vhost. With nethserver6 I was using htwritable but with ns7 I haven’t that any more
Dont think I understand. Turn on SSH, get PUTTY or some other program, log in using SSH, cd to your directory and set perms. Also, download winSCP, login sftp or ssh, navigate to vhost, profit
also nothing wrong with ftp on internal server…go to firewall and allow only to green. That way you can ftp from your network and it blocks outside connections, also fail2ban is amazing for anything network facing, security wise. A must have.
