Exactly!
What exactly are those ACL limitations? As far as I remember, Iāve been able to specify per-user read/write flags for a directory in Samba, and for example this is quite sufficient for me, while gaining support for both Win Pro member clients and other clients.
Thanks
This issue is now tracked on
A nethserver-samba testing package is available. It reverts the effects of the last 2.0.2 release, and restores the default wbclient library from the Samba project.
This means that by default, NTLM auth is still supported, but ACLs canāt be changed from domain workstations /cc @saitobenkei
To enable the support to ACLs from domain workstation (but disable NTLM authentication):
config setprop smb Libwbclient sssd
signal-event nethserver-samba-update
As said, this operation will be soon available from the Server Manager, in Windows file server page.
So, we canāt have āOvo, Galina e Cul Caldoāā¦
(āChicken and the eggā in English)
Sadly not, as for now.
Just released in nethserver-samba-2.0.3-1.ns7.noarch.rpm
