no packages for update
after a restart the mysql is started, but the rest dont work.
Could you paste the output of?
systemctl status nsdc
Also search for any error message in
journalctl -M nsdc
the output of systemctl status is:
â nsdc.service - NethServer Domain Controller container
Loaded: loaded (/usr/lib/systemd/system/nsdc.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2016-12-13 08:32:04 CET; 6min ago
Docs: man:systemd-nspawn(1)
Main PID: 27144 (systemd-nspawn)
Status: "Container running."
Memory: 149.4M
CGroup: /machine.slice/nsdc.service
ââ27144 /usr/bin/systemd-nspawn --quiet --keep-unit --boot --network-bridge=br0 --machine=nsdc
ââ27146 /usr/lib/systemd/systemd
ââsystem.slice
ââdbus.service
â ââ27253 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
ââsystemd-journald.service
â ââ27232 /usr/lib/systemd/systemd-journald
ââsystemd-logind.service
â ââ27252 /usr/lib/systemd/systemd-logind
ââsamba.service
â ââ27260 /usr/sbin/samba -i --debug-stderr
â ââ27263 /usr/sbin/samba -i --debug-stderr
â ââ27264 /usr/sbin/samba -i --debug-stderr
â ââ27265 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
â ââ27266 /usr/sbin/samba -i --debug-stderr
â ââ27267 /usr/sbin/samba -i --debug-stderr
â ââ27268 /usr/sbin/samba -i --debug-stderr
â ââ27269 /usr/sbin/samba -i --debug-stderr
â ââ27270 /usr/sbin/samba -i --debug-stderr
â ââ27271 /usr/sbin/samba -i --debug-stderr
â ââ27272 /usr/sbin/samba -i --debug-stderr
â ââ27273 /usr/sbin/samba -i --debug-stderr
â ââ27274 /usr/sbin/samba -i --debug-stderr
â ââ27275 /usr/sbin/samba -i --debug-stderr
â ââ27276 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
â ââ27277 /usr/sbin/samba -i --debug-stderr
â ââ27280 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
â ââ27281 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
â ââ27283 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
â ââ27284 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
â ââ27393 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
ââconsole-getty.service
ââ27257 /sbin/agetty --noclear --keep-baud console 115200 38400 9600 vt220
Dec 13 08:32:05 xxx.xx.xx. systemd-nspawn[27144]: [ OK ] Started Network Service.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: [ OK ] Reached target Network.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: [ OK ] Started Samba domain controller daemon.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: Starting Samba domain controller daemonâŚ
Dec 13 08:32:05xxx.xx.xx systemd-nspawn[27144]: [ OK ] Reached target Multi-User System.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: [ OK ] Reached target Graphical Interface.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: Starting Update UTMP about System Runlevel ChangesâŚ
Dec 13 08:32:05xxx.xx.xx systemd-nspawn[27144]: [ OK ] Started Update UTMP about System Runlevel Changes.
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: CentOS Linux 7 (Core)
Dec 13 08:32:05 xxx.xx.xx systemd-nspawn[27144]: Kernel 4.4.22-1.el7.elrepo.x86_64 on an x86_64
So the nsdc container is up and samba4 is running. Can you ping its IP address? You can obtain it with
config show nsdc
yes ping is responding
if i view at the domain account is written this now
NetBIOS domain name: xxx
ads_connect: No logon servers
Didnât find the ldap server!
Join to domain is not valid: No logon servers
The container seems good, letâs see the âclientâ side⌠What does the Server Manager report at page âStatus > Domain accountsâ?
/cc @support_team
Letâs see dnsmasq:
systemctl status dnsmasq
â dnsmasq.service - DNS caching server.
Loaded: loaded (/usr/lib/systemd/system/dnsmasq.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2016-12-12 20:06:06 CET; 12h ago
Main PID: 1190 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
ââ1190 /usr/sbin/dnsmasq -k
Dec 13 06:08:32 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPREQUEST(br0) 192.168.100.150 00:04:20:2a:50:91
Dec 13 06:08:32 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPACK(br0) 192.168.100.150 00:04:20:2a:50:91 SqueezeboxRadio
Dec 13 07:45:01 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPREQUEST(br0) 192.168.100.109 e8:50:8b:0a:b8:6a
Dec 13 07:45:01 sxxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPACK(br0) 192.168.100.109 e8:50:8b:0a:b8:6a android-2dec71c06455d059
Dec 13 08:17:35 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPDISCOVER(br0) b8:ee:65:ac:37:0b
Dec 13 08:17:35 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPOFFER(br0) 192.168.100.112 b8:ee:65:ac:37:0b
Dec 13 08:17:35 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPREQUEST(br0) 192.168.100.112 b8:ee:65:ac:37:0b
Dec 13 08:17:35 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPACK(br0) 192.168.100.112 b8:ee:65:ac:37:0b Rainer-Notebook
Dec 13 08:18:29 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPREQUEST(br0) 192.168.100.112 b8:ee:65:ac:37:0b
Dec 13 08:18:29 xxx.xxx.xxx dnsmasq-dhcp[1190]: DHCPACK(br0) 192.168.100.112 b8:ee:65:ac:37:0b Rainer-Notebook
What is the nethserver-sssd version?
rpm -q nethserver-sssd
What does this command say?
realm list
Please check also:
host -t SRV _ldap._tcp.$(hostname -d) $(config getprop nsdc IpAddress)
host -t SRV _ldap._tcp.$(hostname -d) 127.0.0.1
What provider do you have? AD container, too?
nethserver-ssd version is nethserver-sssd-1.0.8-1.ns7.noarch
realm list says
compu-max.lan
type: kerberos
realm-name: COMPU-MAX.LAN
domain-name: compu-max.lan
configured: kerberos-member
server-software: active-directory
client-software: winbind
required-package: oddjob-mkhomedir
required-package: samba-winbind-clients
required-package: samba-common-tools
login-formats: COMPU-MAX%U
login-policy: allow-any-login
compu-max.lan
type: kerberos
client-software: sssd
required-package: sssd
required-package: adcli
login-formats: %U@compu-max.lan
login-policy: allow-realm-logins
Using domain server:
Address: 192.168.100.1#53
Aliases:
_ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan.
Aliases:
[root@sbs ~]# Using domain server:
-bash: Using: command not found
[root@sbs ~]# Name: 192.168.100.1
-bash: Name:: command not found
[root@sbs ~]# Address: 192.168.100.1#53
-bash: Address:: command not found
[root@sbs ~]# Aliases:
-bash: Aliases:: command not found
[root@sbs ~]#
[root@sbs ~]# _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan.
-bash: _ldap._tcp.compu-max.lan: command not found
[root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) 127.0.0.1
Address: 127.0.0.1#53
Aliases:
this are entrys from messages during and after the updates:
systemd-nspawn: Failed to create directory /var/lib/machines/nsdc//sys/fs/selinux: Read-only file system
sbs winbindd[2669]: [2016/12/12 11:33:26.593372, 0] âŚ/source3/libsmb/cliconnect.c:1895(cli_session_setup_spnego_send)
Dec 12 11:33:26 sbs winbindd[2669]: Kinit for SBS$@COMPU-MAX.LAN to access cifs/nsdc-sbs.compu-max.lan@COMPU-MAX.LAN failed: Preauthentication failed
Dec 12 11:33:26 sbs winbindd[2669]: [2016/12/12 11:33:26.939050, 0] âŚ/source3/libsmb/cliconnect.c:1895(cli_session_setup_spnego_send)
sbs [sssd[ldap_child[3345]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Preauthentication failed. Unable to create GSSAPI-encrypted LDAP connection.
You said kinit
failed. Letâs see
cat /etc/krb5.conf
dont get it all in one screen, outpost is:
required-package: samba-common-tools login-formats: COMPU-MAX\%U login-policy: allow-any-login compu-max.lan type: kerberos realm-name: COMPU-MAX.LAN domain-name: compu-max.lan configured: kerberos-member server-software: active-directory client-software: sssd required-package: oddjob required-package: oddjob-mkhomedir required-package: sssd required-package: adcli required-package: samba-common-tools login-formats: %U@compu-max.lan login-policy: allow-realm-logins [root@sbs ~]# compu-max.lan realm-name: COMPU-MAX.LAN -bash: compu-max.lan: command not found [root@sbs ~]# type: kerberos -bash: type:: command not found [root@sbs ~]# realm-name: COMPU-MAX.LAN -bash: realm-name:: command not found [root@sbs ~]# domain-name: compu-max.lan -bash: domain-name:: command not found [root@sbs ~]# configured: kerberos-member -bash: configured:: command not found client-software: winbind [root@sbs ~]# server-software: active-directory -bash: server-software:: command not found [root@sbs ~]# client-software: winbind -bash: client-software:: command not found [root@sbs ~]# required-package: oddjob-mkhomedir required-package: samba-winbind-clients required-package: samba-winbind -bash: required-package:: command not found [root@sbs ~]# required-package: oddjob required-package: samba-common-tools login-formats: COMPU-MAX\%U -bash: required-package:: command not found [root@sbs ~]# required-package: samba-winbind-clients -bash: required-package:: command not found compu-max.lan [root@sbs ~]# required-package: samba-winbind type: kerberos realm-name: COMPU-MAX.LAN -bash: required-package:: command not found domain-name: compu-max.lan [root@sbs ~]# required-package: samba-common-tools -bash: required-package:: command not found [root@sbs ~]# login-formats: COMPU-MAX\%U server-software: active-directory -bash: login-formats:: command not found [root@sbs ~]# login-policy: allow-any-login client-software: sssd -bash: login-policy:: command not found required-package: oddjob [root@sbs ~]# compu-max.lan required-package: oddjob-mkhomedir required-package: sssd -bash: compu-max.lan: command not found [root@sbs ~]# type: kerberos -bash: type:: command not found [root@sbs ~]# realm-name: COMPU-MAX.LAN -bash: realm-name:: command not found [root@sbs ~]# domain-name: compu-max.lan -bash: domain-name:: command not found [root@sbs ~]# configured: kerberos-member -bash: configured:: command not found [root@sbs ~]# server-software: active-directory required-package: samba-common-tools login-formats: %U@compu-max.lan -bash: server-software:: command not found [root@sbs ~]# client-software: sssd -bash: client-software:: command not found [root@sbs ~]# required-package: oddjob -bash: required-package:: command not found [root@sbs ~]# required-package: oddjob-mkhomedir -bash: required-package:: command not found [root@sbs ~]# required-package: sssd -bash: required-package:: command not found [root@sbs ~]# required-package: adcli -bash: required-package:: command not found [root@sbs ~]# required-package: samba-common-tools -bash: required-package:: command not found [root@sbs ~]# login-formats: %U@compu-max.lan -bash: login-formats:: command not found [root@sbs ~]# login-policy: allow-realm-logins -bash: login-policy:: command not found [root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) $(config getprop nsdc IpAddress) Using domain server: Name: 192.168.100.1 Address: 192.168.100.1#53 Aliases: _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. [root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) $(config getprop nsdc IpAddress) Using domain server: Name: 192.168.100.1 Address: 192.168.100.1#53 Aliases: _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. [root@sbs ~]# Using domain server: -bash: Using: command not found [root@sbs ~]# Name: 192.168.100.1 -bash: Name:: command not found [root@sbs ~]# Address: 192.168.100.1#53 -bash: Address:: command not found [root@sbs ~]# Aliases: -bash: Aliases:: command not found [root@sbs ~]# [root@sbs ~]# _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. -bash: _ldap._tcp.compu-max.lan: command not found [root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) 127.0.0.1 Using domain server: Name: 127.0.0.1 Address: 127.0.0.1#53 Aliases: _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. [root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) $(config getprop nsdc IpAddress) Name: 192.168.100.1 Address: 192.168.100.1#53 Aliases: _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. [root@sbs ~]# Using domain server: -bash: Using: command not found Using domain server: Name: 192.168.100.1 Address: 192.168.100.1#53 Aliases: _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. [root@sbs ~]# Using domain server: -bash: Using: command not found [root@sbs ~]# Name: 192.168.100.1 -bash: Name:: command not found [root@sbs ~]# Address: 192.168.100.1#53 -bash: Address:: command not found [root@sbs ~]# Aliases: -bash: Aliases:: command not found [root@sbs ~]# [root@sbs ~]# _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. -bash: _ldap._tcp.compu-max.lan: command not found [root@sbs ~]# [root@sbs ~]# Using domain server: -bash: [root@sbs: command not found [root@sbs ~]# -bash: Using: command not found -bash: -bash:: command not found [root@sbs ~]# [root@sbs ~]# Name: 192.168.100.1 -bash: [root@sbs: command not found [root@sbs ~]# -bash: Name:: command not found -bash: -bash:: command not found [root@sbs ~]# [root@sbs ~]# Address: 192.168.100.1#53 -bash: [root@sbs: command not found [root@sbs ~]# -bash: Address:: command not found -bash: -bash:: command not found [root@sbs ~]# [root@sbs ~]# Aliases: -bash: [root@sbs: command not found [root@sbs ~]# -bash: Aliases:: command not found -bash: -bash:: command not found [root@sbs ~]# [root@sbs ~]# -bash: [root@sbs: command not found [root@sbs ~]# [root@sbs ~]# _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. -bash: [root@sbs: command not found [root@sbs ~]# -bash: _ldap._tcp.compu-max.lan: command not found -bash: -bash:: command not found [root@sbs ~]# [root@sbs ~]# host -t SRV _ldap._tcp.$(hostname -d) 127.0.0.1 -bash: [root@sbs: command not found [root@sbs ~]# Using domain server: -bash: Using: command not found [root@sbs ~]# Name: 127.0.0.1 -bash: Name:: command not found [root@sbs ~]# Address: 127.0.0.1#53 -bash: Address:: command not found [root@sbs ~]# Aliases: -bash: Aliases:: command not found [root@sbs ~]# [root@sbs ~]# _ldap._tcp.compu-max.lan has SRV record 0 100 389 nsdc-sbs.compu-max.lan. -bash: _ldap._tcp.compu-max.lan: command not found [root@sbs ~]# cat /etc/krb5.conf # Configuration snippets may be placed in this directory as well includedir /etc/krb5.conf.d/ [logging] default = FILE:/var/log/krb5libs.log kdc = FILE:/var/log/krb5kdc.log admin_server = FILE:/var/log/kadmind.log [libdefaults] dns_lookup_realm = false ticket_lifetime = 24h renew_lifetime = 7d forwardable = true rdns = false # default_realm = EXAMPLE.COM default_ccache_name = KEYRING:persistent:%{uid} [realms] # EXAMPLE.COM = { # kdc = kerberos.example.com # admin_server = kerberos.example.com # } [domain_realm] # .example.com = EXAMPLE.COM # example.com = EXAMPLE.COM [root@sbs ~]# cat /etc/krb5.conf # Configuration snippets may be placed in this directory as well includedir /etc/krb5.conf.d/ [logging] default = FILE:/var/log/krb5libs.log kdc = FILE:/var/log/krb5kdc.log admin_server = FILE:/var/log/kadmind.log [libdefaults] dns_lookup_realm = false ticket_lifetime = 24h renew_lifetime = 7d forwardable = true rdns = false # default_realm = EXAMPLE.COM default_ccache_name = KEYRING:persistent:%{uid} [realms] # EXAMPLE.COM = { # kdc = kerberos.example.com # admin_server = kerberos.example.com # } [domain_realm] # .example.com = EXAMPLE.COM # example.com = EXAMPLE.COM [root@sbs ~]# cls -bash: cls: command not found
Please comment that line with a #
character, then go back to Server Manager âDomain accountsâ page.
Yes, AD container.
realm list:
[root@ns7test ~]# realm list
ns7.lan
type: kerberos
realm-name: NS7.LAN
domain-name: ns7.lan
login-formats: NS7\%U
ns7.lan
type: kerberos
realm-name: NS7.LAN
login-formats: %U@ns7.lan
Same line âincludedirâ in krb5.conf? Do you have the File server module too?
not sure what you mean, sorry
