I’m working on my test nethserver testing my ssl certificates. I’ve seem to have lost the ability to login as the local nextcloud admin. I do know the password but for some reason it won’t work. I’m hoping I can reset the admin Nextcloud password from the command line and I’m looking to see if anyone else has done this.
I’ve been searching google for an answer and found this from ownCloud:
$ sudo -u www-data php /var/www/owncloud/occ user:resetpassword admin
Enter a new password:
Confirm the new password:
Successfully reset password for admin
I know that Nethserver puts Nextcloud in /usr/share/nextcloud. I’ve tried submitting the above instruction pointing to my location of the occ but I’m getting errors on www-data not found.
Does anyone know if it’s possible and how I can update my local admin password for Nextcloud?
With Nextcloud23 (and probably also with lower versions) I ran into the following issue:
[root@server1 nextcloud]# sudo -u apache /opt/rh/rh-php73/root/usr/bin/php /usr/share/nextcloud/occ user:resetpassword admin
An unhandled exception has been thrown:
OCP\HintException: [0]: Memcache \OC\Memcache\APCu not available for local cache (Is the matching PHP module installed and enabled?)
[root@server1 nextcloud]# sudo -u apache /opt/rh/rh-php73/root/usr/bin/php --define apc.enable_cli=1 /usr/share/nextcloud/occ user:resetpassword admin
The current PHP memory limit is below the recommended value of 512MB.
[root@homeserver1 nextcloud]#
Not sure this needs to be considered somewhere else (like mentioned in the link above, php.ini ?), and maybe also helpful in nethserver nextcloud documentation?
Thanks for the info. Here in the forums we faced the same issue a while back.
There is a wrapper that already applies what you recommend and also a higher PHP memory limit value.
At the time of writing this, the password reset example in the wiki uses this wrapper.
