is there a summary of the error codes and their meanings? I get the same “AccountProvider_Error_1” since I had to reinstall my server and restore the configuration. Strangely only on the Dashboard and Users and groups sites, everything else works. All services are up and running, Domain accounts looks normal and I can logon to my samba shares and SOGo just fine. When I run /usr/libexec/nethserver/list-groups or list-users directly it says (No route to host): IO::Socket::INET6: connect: No route to host.
Unfortunately I can’t find any documentation of how these two programs work. Does anyone have a clue what might be going wrong? Thanks.
Thank you. Indeed, I think the error messages could be more informative. Something like “AccountProvider Generic Error: SSSD exit code 1” would help. But this might be misleading in my case: the sssd and secure logs are okay and the messages log shows only the httpd problem:
> Oct 3 16:42:12 nethserver httpd: [ERROR] NethServer\Tool\UserProvider: AccountProvider_Error_1
Oct 3 16:42:12 nethserver httpd: [ERROR] (No route to host): IO::Socket::INET6: connect: No route to host
Could lead to a IPv6 address in DNS, which is currently not supported on LAN… Please check your DNS settings as nsdc should not contain IPv6 records, and paste here the output of
